    I recently dropped my lg g5 in the toilet, so I dismantled it and cleaned it all and got everything to work fine, but when I changed the volume suddenly sound stops working all together maybe if I reboot it it works again but as soon as I change the volume it stops working.
    any ideas? thanks
    01-02-2018 11:53 AM
  2. Rukbat's Avatar
    Could be a bad earphone jack, a bad speaker, a bad connection on the motherboard ... it has to go into a repair shop for a diagnosis.
    Considering that it's a G5, and you can get them for about $150-$180 refurbished (and probably less for a nicely used one), it may or may not pay to repair it.
    01-02-2018 11:58 AM
  1. why can't I reinstall messenger from my Facebook
    By Android Central Question in forum Android Apps
    Last Post: 01-02-2018, 12:54 PM
  2. To note 8 or not to note 8
    By MPreston in forum Ask a Question
    Last Post: 01-02-2018, 12:01 PM
  3. LG3 calendar doesnt show my rotating 4 days off
    Last Post: 01-02-2018, 11:19 AM
  4. Why is it aimed at Logan paul
    Last Post: 01-02-2018, 11:01 AM
  5. why can't I reinstall messenger from my Facebook
    Last Post: 01-02-2018, 10:38 AM
