    When I go into my application manager it says my Android system isn't running. And none of the Android functions are running either.
    01-10-2018 02:07 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which device do you have? Do you mean that you don't see any of the Android components in the Running Apps menu? Is the device otherwise working normally?
    01-10-2018 02:33 PM
  1. Pokemon GO runs on Galaxy Tab S3, but is not optimized for screen size. Fixes?
    Last Post: 08-12-2018, 08:21 PM
  2. Why isn't Hotspot Shield in BEST ANDROID VPNs list?
    By FAHMI BASSEM in forum Nokia 8 & Nokia 8 Sirocco
    Last Post: 01-10-2018, 06:32 PM
  3. My Phone have to google play services
    Last Post: 01-10-2018, 01:28 PM
  4. Why does my microphone barely pick my voice up.
    Last Post: 01-10-2018, 01:25 PM
  5. Why does my LGk20 pause my music?
    Last Post: 01-10-2018, 01:24 PM
