How do i fix system permission issues
  • Start date Start date
First all of the basics;
What device?
What OS?
What app?
What have you tried?
You say it's a permissions issue, what makes you think that, instead of just a sound being turned off, or something being disabled? Depending on what app you are using they sometimes have a test notifications button in the settings. This would allow you to preview the notification. Have you gone through the settings to see if something is off? Both device and app.
rose1988
