    So, I'm using Smooth System Progress Bar to make my progress bar smoother. It works but the problem is that even if I change the color, it doesn't show that color. Sometimes it changes but most of the time.. No. I think another app is giving a problem with the app but I'm not sure. So what could be the problem?
    01-13-2018 06:45 AM
  2. belodion's Avatar
    Is that a feature on some phone, or an app you’ve downloaded?
    01-13-2018 07:21 AM
  3. DclSilvr's Avatar
    Its an app for rooted device to use with Exposed.
    01-13-2018 07:25 AM
  1. New firmware on firmware finder (mha-l09)
    By bigmick777 in forum Huawei Mate 9
    Last Post: 01-16-2018, 06:00 AM
  2. Hey Google prompt sound disappeared on my Tab S Galaxy tablet how to restore
    Last Post: 01-14-2018, 10:20 PM
  3. Replies: 5
    Last Post: 01-13-2018, 05:46 AM
  4. Front camera stopped working on Sony Z5 compact after battery replaced
    By Android Central Question in forum Sony Xperia Z5 & Z5 Compact
    Last Post: 01-13-2018, 04:58 AM
  5. Front camera stopped working on Sony Z5 compact after battery replaced
