    Is android zte 5.1.1 QI ENABLED
    01-18-2018 10:14 AM
  2. hallux's Avatar
    That's the GREAT thing about "standards" (of which Qi is one), all you need is a device compatible with that standard and it will do what it is designed to do. Any Qi charger should work for your device.
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    01-18-2018 11:01 AM
  1. Flashlight icon, does the Note 8 have one? Thank you for
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 01-20-2018, 11:39 AM
  2. Looking for a good truck mount for the note 8
    By nicktravaglini in forum Samsung Galaxy Note 8
    Last Post: 01-19-2018, 11:11 PM
  3. Replies: 0
    Last Post: 01-18-2018, 04:39 AM
  4. Flashlight icon, does the Note 8 have one? Thank you for
    Last Post: 01-18-2018, 03:18 AM
