    all of a sudden changed!
    I used to use finger reader, and it would take me right to home screen... now it asks the pin code.
    any body know how to avoid it?
    thanks guys!
    01-21-2018 08:36 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this happen all the time, or only occasionally (like after a cold boot)? It's normal for a phone to ask for your backup PIN/password occasionally if you use fingerprint unlock (which is why it's so important to remember your backup PIN). I don't believe there's a way to turn that off if you want to use the fingerprint sensor.
    01-21-2018 11:48 PM
  1. where i can download system files for my samsung tablet3
    Last Post: 01-21-2018, 11:58 PM
  2. Where can I download root software for nexus 5x to connect to it from a Windows PC USB?
    By Android Central Question in forum Nexus 5X Rooting, ROMs, & Hacks
    Last Post: 01-21-2018, 11:51 PM
  3. Navigation bar is too light since last Verizon update
    Last Post: 01-21-2018, 07:38 PM
  4. Replies: 1
    Last Post: 01-21-2018, 07:29 PM
  5. Replies: 0
    Last Post: 01-21-2018, 07:13 PM
