    So basically, I have a problem, I often dont get notifications (Or get them late) And I wonder why it is happening.. Its really pissing me off... Like its important for me to answer my Text message right away.. Not 1h after receiving.. Any idea/suggestion of why its happening?
    Details of my phone :
    Zenfone 3 Max
    Android 7.0
    2GB Ram
    Not Rooted
    01-23-2018 06:15 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Any power-saving modes turned on, or 3rd party power-saving apps installed? Is Restrict Background Data turned on in Settings>Data Usage​?
    01-23-2018 11:29 PM
  3. Dano1200r's Avatar
    Go to Settings, Notifications and check your settings.
    Also go to the Sounds and select the type.
    01-24-2018 05:46 AM
  1. Open a message and comes up on dark background why
    Last Post: 01-23-2018, 06:45 PM
  2. smartswitch problem
    Last Post: 01-23-2018, 05:38 PM
  3. I have Android Messages but cannot enhanced features do not show up
    Last Post: 01-23-2018, 05:19 PM
  4. what is open 2 apps at onmce using one shortcut on the note 8
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 01-23-2018, 03:58 PM
  5. what is open 2 apps at onmce using one shortcut on the note 8
    Last Post: 01-23-2018, 03:02 PM
