    Back in August i went to charge my battery on the Galaxy Note 10.1 and it had a RED X on the battery. When charging the battery was not holding it charge and just went down significantly to 5%. I replaced the cord and still did the same. I just replaced the battery and still has a RED X on the battery. It charged to 95% but i want to get RED X to go away. Is there something else that i need to replace or what needs to be done. Please help.
    01-25-2018 11:46 AM
  2. L0n3N1nja's Avatar
    Did you replace the charger or just the cord?
    The red x means it isn't getting enough power, I had the same issue a couple years ago, using a different charger fixed my issue.
    Dano1200r likes this.
    01-25-2018 11:59 AM
  3. Dano1200r's Avatar
    Yup. Get a good charger.
    01-25-2018 04:29 PM
  4. hallux's Avatar
    With my Note 10.1 (2014), now my mom's, I found that I got that at times and just had to unplug it and plug it back in at the device end and it charged correctly, even with the same cable and charger.
    01-25-2018 04:54 PM
  1. Replies: 16
    Last Post: 02-06-2018, 07:18 AM
  2. Why is my Battery icon showing an X
    Last Post: 01-25-2018, 08:05 PM
  3. Google calendar will not sync on my s8+
    By bluest170 in forum Samsung Galaxy S8 & S8+
    Last Post: 01-25-2018, 12:06 PM
  4. Can I use Sprint International roaming on a Galaxy S6?
    Last Post: 01-25-2018, 11:42 AM
  5. Phone # on auto reject list
    Last Post: 01-25-2018, 11:37 AM
