    I have a Galaxy S7, and I just moved up from the 5. Why is the front facing camera quality significantly worse than it is on the normal front facing camera, and is there any way to fix it? It blurs the entire photo and gets rid of any definition. It was much better on the 5. I havent tried it in natural light, but rhis has been while using front flash in dark and light rooms.
    01-27-2018 08:19 PM
  2. ManiacJoe's Avatar
    An example unedited, full-size image with all the EXIF data would be helpful so that we can see what you are seeing.
    01-28-2018 04:43 AM
  1. Replies: 9
    Last Post: 02-05-2018, 09:07 PM
  2. Why do I have a symbol of a watch on my Android Face Screen
    Last Post: 01-28-2018, 04:55 PM
  3. how to fix a camera problem
    Last Post: 01-27-2018, 10:49 PM
  4. What is sec.abt for
    Last Post: 01-27-2018, 10:47 PM
  5. why can't I see all files I've downloaded in my download file?
    Last Post: 01-27-2018, 10:46 PM
