    When i charge my galaxy s5 it charges but when i disable charging my battery quickly dies like 99% then 98 then 97 .... and after 20 min it comes to 75 and then
    How to fix that problem.
    01-29-2018 11:27 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this happen in Safe Mode as well? https://support.t-mobile.com/docs/DOC-28456. Or after a cache partition wipe? https://support.t-mobile.com/docs/DOC-28492
    It may help to see some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    01-30-2018 02:01 AM
  1. Can I unsync my secondary folders in Gmail.
    By Leanne Parker2 in forum Samsung Galaxy S5
    Last Post: 02-04-2018, 04:20 AM
  2. Volume decreases when playing audio with headphones
    By Android Central Question in forum OnePlus 5 & 5T
    Last Post: 01-30-2018, 01:16 PM
  3. I accidentally sideswiped a new gmail and its gone, How do I recover the email?
    Last Post: 01-30-2018, 12:11 PM
  4. Why can't I log on to my account from my phone?
    Last Post: 01-30-2018, 02:02 AM
  5. Suddenly my phone wont connect wifi
    Last Post: 01-29-2018, 10:31 PM
