1. Karoluna's Avatar
    I have set up a trusted place setting so my new phone stays unlocked at home, but every so often it locks, any tips, folks?
    02-01-2018 05:17 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is your phone's Location set to High Accuracy or Battery Saving? If you're not using the GPS radio, the phone might think you're somewhere up to 100-200 yards away, which would place you outside your Trusted Location.
    02-03-2018 01:48 AM
  1. how to turn on massenger ringtone sound on speaker with hand free on
    Last Post: 02-02-2018, 12:39 PM
  2. Why doesnt my green fully charge light not come on
    Last Post: 02-01-2018, 07:43 PM
  3. Samsung s8 active screen turns on and off repeatedly.
    Last Post: 02-01-2018, 04:58 PM
  4. Why can't I use my SD card to free up space on my Moto G?
    Last Post: 02-01-2018, 04:18 PM
  5. All notification sounds are the same
    By Hope_4_Life10 in forum Ask a Question
    Last Post: 02-01-2018, 03:41 PM
