    There was one update about 3 or 4 months ago and I never updated it then recently I said okay let me update my phone... then it stopped working.. then another one about a month ago Ang out didn't change anything that i can see at least did out seemed like a pointless update
    02-04-2018 06:56 AM
  2. Kibaikasu's Avatar
    If the recent update that was done was for your Android OS, then it is possible that you will need to manually enable the app permissions for it to work via the Application Manager in your phone's Settings. Try that and see if it helps.
    02-04-2018 09:52 AM
  1. How much does encryption affect phone performance?
    By mr_master in forum General Help and How To
    Last Post: 07-14-2018, 06:55 AM
  2. my phone issamsung gallaxy s4 notting show on the screen why is not work ?
    Last Post: 02-06-2018, 01:40 AM
  3. Active Edge and google pixel buds
    By Lefank in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 02-04-2018, 02:00 PM
  4. Data not working
    Last Post: 02-04-2018, 06:57 AM
  5. Galaxy S6 won't turn on pulsing blue light.
    By Winged_Kuribo in forum Ask a Question
    Last Post: 02-04-2018, 05:51 AM
