    I have been using a 0,7 Ampere charger for my Huawei p8 and I noticed that the charging process takes longer time and the battery drains really fast after unplugging the charger, does using a 1,5 Ampere or higher can make the battery last longer?
    Plz help!
    02-05-2018 05:16 AM
  2. Tim1954's Avatar
    Sounds like your battery is in the way out... Replace it before it lets you down at the most inconvenient time...
    02-05-2018 06:04 AM
  1. Home button-like issue
    Last Post: 02-05-2018, 01:18 PM
  2. I lost my status bar message and battery
    Last Post: 02-05-2018, 10:01 AM
  3. Replies: 1
    Last Post: 02-05-2018, 06:06 AM
  4. Why is a recycle battery symbol on the right top side of my screen on my Note 5
    Last Post: 02-04-2018, 04:15 PM
  5. To the samung s8 people with screen time out issues.
    Last Post: 02-04-2018, 08:52 AM
