    Hi everybody,
    i have this Samsung Note 2, i know its little older but want to use it for Time Lapse
    the problem is power to the phone. i have try these and hoping someone has more option that i can try.
    1. Laptop to USB charging going down
    2. Power-plug to USB charging going down
    3. tried different cables
    4. tried to without battery, goes of after around 5 seconds
    5. someone write somewhere about custom conf of the phone - if you know more please define more of that subject
    6. tried different powerplugs
    regards
    AGuyFromGreenland
    02-06-2018 12:11 PM
  2. belodion's Avatar
    Is the battery still good?
    02-06-2018 12:15 PM
  3. Malik Lange's Avatar
    Hi, didnt expext to have someone answer so early yeah that battery good, tried to leave it from power-plug and just to dried it out
    02-06-2018 12:48 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! The camera uses a significant amount of energy, so if it's on constantly, the power usage might still outstrip the charging rate. Does it charge normally when you're not actively using the camera?
    02-06-2018 01:34 PM
  1. Replies: 2
    Last Post: 02-06-2018, 02:51 PM
  2. I am trying to close tabs on my samsung on 5. help
    Last Post: 02-06-2018, 12:46 PM
  3. How to edit music behind bluetooth on galaxy note 4
    Last Post: 02-06-2018, 10:27 AM
  4. My tablet seems to go into a hibernation state
    Last Post: 02-06-2018, 10:25 AM
  5. not have samsung kies and cannot connect with laptop
    Last Post: 02-06-2018, 10:11 AM
