    Is there a solution for the phone battery htc m10 ??? Can I go back to Android 6 ?????
    02-06-2018 01:11 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Can you give more details? Do you mean that the battery seems to drain more quickly on Nougat?
    02-06-2018 01:29 PM
  3. Taibi Younes's Avatar
    When using Wi-Fi or 4G, the battery level starts to decrease. When charging the phone is 100% after 5min becomes 95%. Is Android 7 is the reason?
    02-06-2018 05:00 PM
  4. B. Diddy's Avatar
    As you probably know, there are many reasons for battery drain. If this started right after updating to Nougat, then it's worth doing a cache partition wipe, since that can sometimes help: https://support.t-mobile.com/docs/DOC-25804.
    If that doesn't help, then it would help to see some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    02-06-2018 08:32 PM
  1. Nokia 8 Auto Focus problem
    By Juanan Lopez in forum Nokia 8 & Nokia 8 Sirocco
    Last Post: 12-26-2018, 01:24 PM
  2. Weird small line in the corner of the screen [J5-2015]
    Last Post: 02-06-2018, 08:36 PM
  3. samsung note 2 battery going down while charging
    Last Post: 02-06-2018, 01:34 PM
  4. Replies: 1
    Last Post: 02-06-2018, 01:08 PM
  5. Replies: 0
    Last Post: 02-06-2018, 12:20 PM
