led indicator is not working on my phone LG x230i. how to turn on led indicator?? i am not able to find notification led in settings... do I need to download any app to turn on led light???
"To use the LED Lights on your device, open the Settings, tap on Brightness & display in the device section and click on Indicator light. You will find options like Calls, Messages, Notification, Charge and Low battery. Tap on the options for which you want to get an LED notification on your device."
