    Charger is connected but battery isn't charging only 3% battery is charged from 3 hrs. Battery isn't charging more than 3% why n what I have to do?
    02-14-2018 08:07 AM
  2. belodion's Avatar
    Is the 3% an indicated charge, or is the battery truly only at 3%?
    02-14-2018 08:11 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Are you able to try a different battery?
    02-14-2018 11:05 AM
  4. Rukbat's Avatar
    Have you tried a different charger? A different cable? (Just to make sure that your charger or cable didn't go bad.)
    If the charger and cable are both good, there are two possibilities, either the charging port in the phone is bad or the battery is bad. (If you regularly let the battery get down to 3%, I'd suspect that it's the battery. Never let the battery - any lithium battery - get down below 40%.)
    If it's a bad battery, and it's removable, you can get a new one and replace it. Otherwise it has to go into a repair shop, either for a new battery or for a new charging port. Get a price first - if it's a cheaper phone, it may be cheaper to get a new one than to fix the old one.
    02-14-2018 12:06 PM
  5. ClarityDesigns's Avatar
    Sounds like a faulty battery, but if you have try another charger first. It could be the port like Rukbat said. But I'd try the cheaper options first.
    02-14-2018 06:53 PM
  1. Why is my LG Aristo locked on master reset reboot screen
    Last Post: 02-11-2018, 09:23 PM
  2. YouTube TV does not work correctly
    By mgiff06 in forum Samsung Galaxy Note 8
    Last Post: 02-11-2018, 09:16 PM
  3. Why my phone repeatedly sends the same text message multiple times?
    Last Post: 02-11-2018, 09:15 PM
  4. Wet Charging Port Warning Going On & Off
    By Joshua_Muldoon in forum Samsung Galaxy Note 8
    Last Post: 02-10-2018, 03:12 PM
  5. Is this how the owner of the account gets information off my phone
    Last Post: 02-08-2018, 07:18 PM
