    I'm using Samsung Galaxy A9.
    First problem:My phone lagged for a while for multiple times when I'm using apps.When I remove the app history and went home button,I saw Contacts Provider. Everytime it lags,Contacts Provider shows up.I tried to force stop Contacts Provider but it shows up again a few minutes later.
    Second problem:I download Youtube app.The app looks old and I could not update in my phone.Even if there is a latest update,I tried to update it but i ended up opening the old app.When I watched videos in the app,it crashed sometimes.
    Third problem:My google services won't run.I go to google settings and go to Apps with Google+ Sign In but it says that it couldn't load apps,try again later.I use another account but it shows the same problem
    How do I fix these problems?
    02-17-2018 02:03 AM
  2. B. Diddy's Avatar
    Welcome to Android Central!
    Contacts Provider is probably essential for syncing your contacts, so I doubt that's the problem -- but just in case, go to Settings>Accounts>Google and see if there is a Sync Error for Contacts. If something is wrong with contact syncing, that might bog things down.
    Otherwise, see if the problem persists after a reboot. If it does, see if a cache partition wipe helps: SAMSUNG Galaxy A9 - Recovery Mode - HardReset.info. If that still doesn't work, see if the problem persists in Safe Mode: SAMSUNG Galaxy A9 - Frequently Asked Questions about resetting your device - HardReset.info
    YouTube should come preinstalled on the phone, unless it was intended for a market where Google services are blocked. Did the phone come with the Play Store preinstalled, or did you have to install it manually? Are you trying to install or update YouTube through the Play Store?
    02-17-2018 03:54 PM
  1. I'm not updating my phone anymore...
    By flyingkytez in forum LG V20
    Last Post: 02-22-2018, 08:43 PM
  2. V long time to wake fir brand new Samsung Note 8
    Last Post: 02-19-2018, 12:40 PM
  3. My LG stylo3 is not marking any sounds
    Last Post: 02-19-2018, 12:38 PM
  4. Ugent, if it's not work, i have to return note 8.
    By qwersjs in forum Samsung Galaxy Note 8
    Last Post: 02-19-2018, 09:50 AM
  5. How to undo vestiges of themes past
    Last Post: 02-17-2018, 12:35 AM
