Step 1: Clear devices from your phone's memory
Open your phone's Settings app Settings app.
Tap Connected devices and then Bluetooth.
If you see devices you're not currently using, next to each device name, tap Settings Settings and then Forget.
If you paired your phone and car before, next to your car's name, tap Settings Settings and then Forget.
Step 2: Clear devices from your car's memory
To clear devices paired with your car, follow your car's manual.
Clear any devices you're not currently using.
If you paired your phone and car before, clear your phone.
Step 3: Refresh the device list, then pair
To learn whether to pair from your phone or car, check your car’s manual.
Pair from your phone
Check that your car is discoverable and ready to pair.
Tap More More and then Refresh and then your car's name.
Pair from your car
Tap Connected devices and then Bluetooth. Keep this screen open.
On your car's list of devices, pick your phone's name.
If asked, confirm that the PINs shown on your phone and car's screens match. Then tap Accept or Confirm.
Next to “Contact sharing," check the box. hope this helps
