    The internet doesn't work without wifi
    02-18-2018 08:57 AM
  2. Rukbat's Avatar
    Are you sure you have a data connection? Is mobile data turned on?
    If the answer to both questions is yes, contact your carrier.
    02-18-2018 04:05 PM
  1. My internet dont work unless the WiFi is on wont work outside or in the car
    Last Post: 02-18-2018, 04:06 PM
  2. Why is my UC browse cannnot move to SD card?i
    Last Post: 02-18-2018, 01:15 PM
  3. My internet dont work unless the WiFi is on wont work outside or in the car
    Last Post: 02-18-2018, 01:13 PM
  4. Why does my screen go black
    Last Post: 02-18-2018, 09:19 AM
  5. Replies: 1
    Last Post: 02-18-2018, 09:16 AM
