    every time i try to unlock my phone it just goes back to the lock screen if i repeatedly swipe up i see the number code for a fraction of a second ive tried using the camera, to get in the WiFi, the Bluetooth, ive tried phone calls, screenshots, and texts nothing works HELP!!!!!!! it only gets to the wall paper through safe mode but i deactivated safe mode and it didn't work.
    02-18-2018 11:59 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! So when you swipe up to get to the PIN entry, it never quite swipes all the way up? Are you certain you're swiping all the way up?
    02-19-2018 02:17 AM
  1. Screen repeatedly turning on home button and power issues. S7 Android 7
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 02-19-2018, 09:55 PM
  2. Replies: 2
    Last Post: 02-19-2018, 05:22 PM
  3. How do I set a designated sound for only my alarm?
    Last Post: 02-19-2018, 04:31 PM
  4. Why I can't customize my contacts ringtones to songs on u-tube
    Last Post: 02-19-2018, 12:16 PM
  5. How long does it take to factory reset my Samsung Galaxy S6 Edge Plus?
    Last Post: 02-19-2018, 02:22 AM
