    After formatting SD card as internal memory my default camera cant start. But others camera apps working fine. But if i again make SD card portable memory again default camera works again. How can I use SD card as internal and also the default camera again. Android Nougat 7.0.
    02-19-2018 03:55 PM
  2. jasonandrews25788's Avatar
    it just a problem with the camera app code.
    it depends on how your phone manufacturer built the camera app.
    02-19-2018 04:44 PM
  3. Laura Knotek's Avatar
    Welcome to Android Central. What phone do you have?
    02-19-2018 04:51 PM
  1. Can the sync number on AT&T be used directly
    By michail71 in forum Samsung Gear S3
    Last Post: 02-21-2018, 03:26 PM
  2. Sd card not detected
    Last Post: 02-20-2018, 09:22 AM
  3. How can I get my calculator historie back after deleted
    Last Post: 02-19-2018, 04:48 PM
  4. Replies: 0
    Last Post: 02-19-2018, 03:38 PM
  5. why cant i get my tablet to turn on
    Last Post: 02-19-2018, 02:50 PM
