A
Android Central Question
I have a HTC U11+ running on an Android 8.0 . I have tried find a way to block wangiri calls with a certain pattern , for instance all calls starting with country code +212 but there seem not to be any way built into the phone. There are a blocked number function in the U11 but this refers to an explicit number and not patterns.
If you go into the blocked number , then add number , the keypad popup also have W P N along with the standard numbers , can they be used in any hidden way??
