    Alcatel IDEAL unlocked Android phone stuck to 2g/Edge
    I bought an unlocked Alcatel Ideal 4060a (AT&T) model from Lazada Philippines a couple of months ago, but problem is that the network doesn't change at all its always at 2g/EDGE no matter what i do or which network i put inside the phone.
    Am currently using Globe which is a 4g Sim card and the phone is unlocked to any network.
    And there is no option in the settings that you normally choose from your preferred network mode.
    So i stated googling for the solution when i came across this code (*#*#4636#*#*) which i can use to change my preferred network, but whenever i change it, nothing happen, i mean nothing at all, all it does is that, when i select "only WCDMA" i will not get service/network, when i select "LTE only" no network, the only thing that work is GSM or WCDMA preferred.
    I need your help!!!
    02-24-2018 11:38 PM
  2. belodion's Avatar
    Does it support the right radio bands for your region? Check which model version it is in Settings, About Phone.
    02-25-2018 04:23 AM
  1. Q18 smartwatch is on Military time how do I get it to regular time
    By Android Central Question in forum Smartwatches (Non Android Wear / Wear OS)
    Last Post: 01-21-2020, 03:37 PM
  2. Replies: 1
    Last Post: 02-25-2018, 07:22 PM
  3. a problem with "QuitNow" for Android firefox
    By reble in forum Android Apps
    Last Post: 02-25-2018, 07:16 PM
  4. i can't move my photos to applock
    Last Post: 02-25-2018, 04:24 AM
