1. jac0bManing's Avatar
    Hi, I have had a new phone for less than a month (BQ Aquarius V with Nougat 7.1.2) but since one week ago, more or less, it started to act up. Basically, it will randomly start highlighting options in the screen and either clicking on them or not.
    Examples:
    Home (https://imgur.com/rUPjLqo)
    . It almost always picks the leftmost app.
    Home 2 (https://imgur.com/i9Zr9ge)
    . If I move the shortcut, it goes to the next.
    Home 3 (https://imgur.com/kS3vB1G)
    . But sometimes it will highlight the rightmost and open it.
    Apps (https://imgur.com/rW5WyQv)
    . Also happens inside apps.
    Apps 2 (https://imgur.com/39B4DSq)
    . Inside chrome, in this case it will pick the first suggestion and mess up my query.
    Using another launcher (https://imgur.com/XFvZICb)
    . Same thing even if I switch the launcher from Nova to Google now.
    It's really annoying when it happens because it starts clicking on things while I use the phone. I even tried taking a video, but when I did, the problem stop. You think is a hardware or software problem? I have both downgraded and upgrade the device and the problem persists.
    Thanks for you opinions
    02-25-2018 04:09 AM
  2. Rukbat's Avatar
    It could be a virus, it could be some corrupt software or it could be a bad digitizer layer on the screen. It's not possible to troubleshoot that kind of problem without having the phone.
    02-25-2018 12:19 PM
  1. HDR+ on the Galaxy Note8
    By D13H4RD2L1V3 in forum Samsung Galaxy Note 8
    Last Post: 02-27-2018, 11:08 PM
  2. Restoring my activities on Calendar.
    By greenmary1948 in forum Samsung Galaxy S4
    Last Post: 02-25-2018, 06:47 PM
  3. assigned IP of connected notebook in Tethering always the same?
    By Peter Steiner in forum General Help and How To
    Last Post: 02-25-2018, 12:35 PM
  4. I just bought an Olixar tempered glass screen protector and...
    By Eggmundo in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 02-25-2018, 08:32 AM
  5. Why can I not access porn on my j3
    Last Post: 02-25-2018, 05:05 AM
