    Battery percentage not moving and only way charge phone have to be turn completely off with charger attached
    02-26-2018 12:26 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Are you connecting the charger to a wall outlet, a computer USB port, or a portable battery? Have you already tried a different USB charging cable?
    02-26-2018 03:45 PM
  3. Rukbat's Avatar
    If you're using a charger that plugs into the wall, that's usually the sign of a failing battery.
    02-26-2018 04:17 PM
  1. Pixel 2 not water resistant?
    Last Post: 09-13-2018, 04:58 AM
  2. My android says its a linux build is that normal?
    Last Post: 02-26-2018, 06:03 PM
  3. My sPen doesn't sound an alarm either when removed or when left.
    Last Post: 02-26-2018, 04:37 PM
  4. Why does my husband delet gallery3d
    Last Post: 02-26-2018, 12:08 PM
  5. I need to download from playstore on my galaxy s8
    Last Post: 02-26-2018, 12:03 PM
