    Hi there,
    I dropped my N4 from quire a short height onto the leg of a metal chair. My phone wasn't charging beyond 70%. I went to remove my battery to see if taking it in and out would fix it and I noticed to my horror the housing around the charging port was dented and bent in, albeit I can still put my charger in there and still charges.
    I replaced the battery with a Samsung branded one from a local repair shop and they look identical but it really doesn't hold a charge very well. I turn my phone off at night with 100% charge. Within 2 minuets of using it it had gone down to 95%. Its now 67% and I haven't even done anything on it apart from a minuet on Instagram and on the Internet for 10 minuets. Normally it would be at least 90% if that.
    What is the problem, the housing which is damaging the port or the battery? I'm taking it to a service centre but do you think it will be repairable? Its only about a month and a bit old and was a lot of money!
    Any help will be much appreciated
    03-06-2018 06:40 AM
  2. belodion's Avatar
    A diagnosis via a forum is hardly possible alas. Whatever is wrong with it, it will need to be put into the hands of a repairer for assessment.
    03-06-2018 08:08 AM
  3. Rukbat's Avatar
    With laser printers it's not difficult for a battery seller to sell used off-brand batteries with official-looking Samsung labels. I'd return the battery and try a different vendor. (I went through 5 battery vendors for my Note 3 before I went back to Anker. They're more expensive, but they work.)
    03-06-2018 02:25 PM
  1. Replies: 2
    Last Post: 03-16-2018, 05:54 AM
  2. Replies: 1
    Last Post: 03-06-2018, 12:14 PM
  3. does motorola x play supports wireless charging?
    By Android Central Question in forum Moto X
    Last Post: 03-06-2018, 06:39 AM
  4. Replies: 0
    Last Post: 03-06-2018, 04:20 AM
  5. Youtube not working on lenovo k3 note
    By Rashmi Dholakia in forum Ask a Question
    Last Post: 03-06-2018, 03:46 AM
