A Android Central Question Mar 6, 2018 #1 My smartphone automatically switched off at battery bellow 30% charge.after that login phone again,it become very hot and battery reduce speedly.
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,416 10,747 113 Mar 6, 2018 #2 Welcome to Android Central! Which phone? The battery is probably failing. If the battery is removable, try a new one. Upvote 0 Downvote
Rukbat Retired Moderator Feb 12, 2012 44,532 46 48 Mar 6, 2018 #3 And if you keep running it down way below 30%, it's going to fail quickly even if you replace it with a good one. Lithium batteries are not deep discharge batteries. (We use them because they're the lightest batteries we can make.) Upvote 0 Downvote
