    I got phn unlocked and used a straight talk activate own device sims my inter net and everything works great but can't get audio when on call
    Why
    03-09-2018 02:48 AM
  2. Rukbat's Avatar
    No audio from the call, or no audio like music?
    If the latter, that's common with a lot of phones.
    If no phone call audio, Save everything (see Backing up an Android Device), then reflash the firmware (see [Samsung] How to flash Stock ROM via ODIN). It's pretty trivial (although you could die of boredom) to flash a Samsung. Then make a call and see if it works.
    If not it's a hardware problem, so it will have to go into a repair shop.
    If that fixed it, just restore everything you backed up and you're in business.
    03-09-2018 02:01 PM
  1. Replies: 4
    Last Post: 10-19-2018, 05:42 AM
  2. Samsung Galaxy S2 - how do I bring my torch back?
    By CubeWizard in forum Samsung Galaxy S2
    Last Post: 03-12-2018, 02:20 PM
  3. Replies: 3
    Last Post: 03-09-2018, 03:59 PM
  4. Set WiFi Hotspot timeout to anything other than 5 or 10 minutes?
    By UglyStuff in forum Android 7.0 Nougat
    Last Post: 03-09-2018, 02:26 AM
