1. Sarmad Sidqy's Avatar
    It's screen is always has yellow tint it started a month ago but sometime it turns to normal color for a minute or less and this is very rare when it turns to normal colors
    03-10-2018 02:03 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Any power-saving modes or blue light filter apps installed? Does this also happen in Safe Mode? https://support.t-mobile.com/docs/DOC-28897
    03-10-2018 03:46 AM
  3. Sarmad Sidqy's Avatar
    Yes it also happens in safe mode and there isn't any screen filter apps installed
    03-12-2018 08:08 AM
  4. B. Diddy's Avatar
    It sounds like a screen problem -- you'd have to bring it to a repair shop. Or, if you're handy, you could try opening the phone up yourself and seeing if there's a loose connection.
    03-12-2018 12:41 PM
  1. Battery - Galaxy Note 10.1 2014
    By lbabus in forum Hardware Hideaway
    Last Post: 03-19-2019, 05:42 PM
  2. cant see text messages on the notification bar galaxy s9
    Last Post: 02-09-2019, 08:33 PM
  3. Samsung Galaxy S8+ - Black
    By JoshDunc in forum Marketplace Archive
    Last Post: 04-03-2018, 08:54 PM
  4. How can a disabled app be running on my Samsung phone?
    Last Post: 03-10-2018, 03:36 AM
  5. Why S8 plus doesn't show the fast dialing screen that I used in my S7?
    Last Post: 03-10-2018, 01:44 AM
