    I bought a tab pro s used however, there is no wall plug for it. Will an s6 adaptive charger work the same?
    03-12-2018 04:56 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The TabPro S (which is a Windows tablet, not Android) charges using the USB-C port, so you wouldn't be able to use the S6's charging cable (which is microUSB-A). You'd need at least a cable that is USB-C on one end and regular USB-A on the other to plug into the S6 wall charging plug.
    03-12-2018 08:36 PM
  1. Is there a phone recorder that works with Pixel 2 via Bluetooth?
    By Android Central Question in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 03-14-2018, 12:19 AM
  2. Samsung galaxy s6 edge and gear 2 watch
    By artemis95 in forum Samsung Gear S2
    Last Post: 03-12-2018, 08:45 PM
  3. My sd card isn't working right
    Last Post: 03-12-2018, 08:42 PM
  4. Problem with downloading Google Movies to SD Card
    Last Post: 03-12-2018, 08:38 PM
  5. Is there a phone recorder that works with Pixel 2 via Bluetooth?
    Last Post: 03-12-2018, 03:01 PM
