    my Motorola Moto C Plus and my android system is nougat 7 do not recognize USB device on mac I have tried with another cable as well and I even googled it I downloaded Motorola USB driver even enable developer options USB debugging is on as well please help besides that I have read many forums I did find not a solution for my issue.
    03-13-2018 05:04 AM
  2. Rukbat's Avatar
    Plug the phone into the Mac. Pull down the notification bar. Look for a USB notification. (If there's no choice showing, tap the notification.) Choose "Transfer files" or "MTP". Then it should show in the computer. (If it's set to "Charge only" or "Charge device" or something like that, it won't show.)
    03-13-2018 02:15 PM
  1. Edge notification light is not working when display is off on s9+.
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 03-20-2018, 01:29 PM
  2. HOMTOM 16 AND HOMTOM 7 are without magnetic sensor
    Last Post: 03-13-2018, 02:35 PM
  3. Can't seem to get this new phone to work on my sim card...i got a new 4Glte
    Last Post: 03-13-2018, 05:10 AM
  4. Does the always on display on galaxy s 9 burn screen
    Last Post: 03-13-2018, 01:34 AM
  5. Fastboot stucks on three dots
    By gogita kupatadze1 in forum Ask a Question
    Last Post: 03-13-2018, 01:26 AM
