Device not starting after Battery change
  • Start date Start date
A
Android Central Question
I changed the battery of my phone and run into some issues now.
I can start the phone into Download Mode. The display turns blue shows "Download mode" and can be turned off or continued. This works without charger so i guess the battery can't be broken.
When connected to charger the phone just shows the empty battery with a flash in the middle not so acutal percentage.
The phone can't be started in recovery mode or normal mode. Does somebody have any advice?
Phone: Galaxy S7
Everything else is in original state. No root or custom recovery etc.
Welcome to Android Central! Are you able to try the previous battery or any other battery? Does the same thing happen?
Ttodd
