    It'll start to make a phone call and then just cuts off and it's not letting me receive calls is going straight to voicemail or doing nothing
    03-22-2018 04:46 PM
  2. belodion's Avatar
    Swipe down from the top of the screen to find the DND shortcut, or look for the setting in Settings, Sound & Notification.
    03-22-2018 04:52 PM
  3. RumoredNow's Avatar
    Hold up... Do Not Disturb should not keep you from making calls out.
    Sounds like something else is going on.
    Can you join the site and reply in this thread with more details?
    What carrier? What phone?
    Have you rebooted?
    Have you tried going into Airplane mode and then shutting that off to force your local towers to "re-recognize" you?
    Have you removed the SIM and inspected it for possible faults and made sure it is seated properly when you reinsert it?
    When attempting to make a call what exactly happens when it "just cuts off"? Does the dialer crash (disappear from the screen and your recent apps screen)? Does the call dial and then you get a tone? An error message? Please define "just cuts off" to help us recognize what the problem might be.
    03-23-2018 09:22 AM
  1. Replies: 33
    Last Post: 01-19-2019, 11:53 AM
  2. Replies: 4
    Last Post: 03-23-2018, 04:54 PM
  3. How do I turn off vibration for Facebook App on Samsung S9+
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 03-22-2018, 05:59 PM
  4. Is Textra very reliable?
    Last Post: 03-22-2018, 05:57 PM
  5. Casting to a DVD system in an old car
    By bmbriefs in forum General Help and How To
    Last Post: 03-22-2018, 05:39 PM
