    If i do a speed test on my laptop with a 2.4ghz wireless card i get about 30mb download doing the same test from the same distance also with 2.4ghz on my phone i get 2mb download? What can i do
    04-03-2018 08:48 AM
  2. djrakowski's Avatar
    Which phone? Does this happen on one specific WiFi hotspot, or does it happen with all of them?
    04-03-2018 09:37 AM
  3. belodion's Avatar
    You haven’t given us enough information.
    https://r.tapatalk.com/shareLink?sha...4&share_type=t
    04-03-2018 11:40 AM
  4. Rukbat's Avatar
    Are you doing the speed test from the same server for both? (Tests to different servers will give you different results.)
    Are you doing 10 tests and averaging them, on each? (One glitch in the path from the server to you can halve one test. Doing an average of 10 will get you closer to reality.)
    04-03-2018 03:28 PM
  1. How about azdome wireless charger than Samsung wireless charger?
    By loniuk in forum Samsung Galaxy Tab S3
    Last Post: 04-03-2018, 03:51 PM
  2. Replies: 2
    Last Post: 04-03-2018, 03:39 PM
  3. What is the VideoShots folder in Device folders
    Last Post: 04-03-2018, 02:23 PM
  4. Replies: 1
    Last Post: 04-03-2018, 10:53 AM
  5. Why dont i dont get results from the 3800 mah battery? It drains fast why !?
    Last Post: 04-03-2018, 02:06 AM
