    So I own a Samsung Galaxy S7 and, for whatever reason, the timer (NOT the alarm) does not make a sound when the phone is on silent or vibrate. I know that from settings I can change the volume button of notifications and systems, however, that is not an option when the phone is set on silent/vibrate. They are automatically set on mute and there's nothing I seem to be able to do about it. I've had this problem ever since I got the phone, have reset it and tried to fixed - nothing has worked. Any idea?
    04-12-2018 07:40 AM
  2. Rukbat's Avatar
    Silent means "no sound" - including the timer. There's no "silent except for the timer" mode.
    04-12-2018 02:59 PM
  3. DjangoByNight's Avatar
    This worked for me on the S4, and you might want to try it on your S7.
    On Androids: from the Home screen, touch Apps > Settings > Blocking mode.
    In case you also have an iPhone: check settings for Do Not Disturb mode.
    04-22-2018 11:24 AM
  1. phone outo restart
    By Nikhil videos in forum Ask a Question
    Last Post: 04-12-2018, 03:01 PM
  2. Ok Google says 'there is no phone number' for any contacts
    By aidimech79 in forum Samsung Galaxy Note 8
    Last Post: 04-12-2018, 07:32 AM
  3. Galaxy S8+ Battery issues.
    By AR91 in forum Samsung Galaxy S8 & S8+
    Last Post: 04-12-2018, 07:27 AM
  4. Will I lose my profile or all my friends on facebook if I clear data in settings?
    Last Post: 04-12-2018, 06:31 AM
  5. my cherry mobile model: astro 2b wont turn on
    Last Post: 04-12-2018, 05:34 AM
