Rukbat Retired Moderator Feb 12, 2012 44,529 26 0 Visit site Apr 14, 2018 #2 A face is split? Or the screen is split? If the screen, one app is split somehow? Or you have two apps on the screen at the same time? (If it's the last one, keep hitting the back button until you're back at a single screen.) Upvote 0 Downvote
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,592 4,729 113 Visit site Apr 15, 2018 #3 Welcome to Android Central! It'd help to know which phone you have. Upvote 0 Downvote
