    When u trun on ur phone it goes to homw screen not lock screen so gir expamle i trun on my phone it does not go on lock screen only home screen and i tryed to change pin and it does not work it says write curret pin and when i check underneath it it says u ve no pin i tryed alot but someone please help really and ignore the spelling mistakes please and thank you.
    04-20-2018 08:32 PM
  2. Morty2264's Avatar
    Welcome to Android Central! Go into your Security Settings within your Settings app - perhaps you had accidentally turned off the lockscreen setting at some point. Or, try restarting your phone and see if that fixes it.
    04-20-2018 08:37 PM
  3. Dano1200r's Avatar
    What Morty said. :Go to Settings, select Lock Screen and Security, select Screen Lock Type. Select PIN. Confirm and save.
    04-20-2018 08:52 PM
  1. people can't hear me with my headset in but I can hear them what do I do
    Last Post: 04-22-2018, 01:46 PM
  2. Replies: 3
    Last Post: 04-22-2018, 01:44 PM
  3. How do I reset my ringtone? I hit the wrong option.
    By dianamajig in forum Samsung Galaxy Note 8
    Last Post: 04-21-2018, 01:48 PM
  4. How do I reset my ringtone? I hit the wrong optione.
    Last Post: 04-20-2018, 11:35 PM
  5. My Screen Recording Lags??
    Last Post: 04-20-2018, 07:45 PM
