    Requirement for detecting the vertical plane glass surface using ARCore framework, the framework well suited for detecting the planes with contrasting features but is there any method for vertical glass plane detection using ARcore?
    04-24-2018 04:55 AM
  2. Rukbat's Avatar
    You can't detect hardware that's not electrically connected to the motherboard. If the glass is the digitizer plane, you can detect touches to it, but if it's not you can only detect the touches that get through to the digitizer plane.
    04-24-2018 05:22 PM
  1. Replies: 5
    Last Post: 05-01-2018, 04:42 AM
  2. How to check an unknown number.
    Last Post: 04-24-2018, 03:22 PM
  3. Why did my Samsung say used code running all the sudden
    Last Post: 04-24-2018, 02:13 PM
  4. Replies: 1
    Last Post: 04-24-2018, 02:08 PM
  5. how to block all unknown numbers except contact number on iphone
    Last Post: 04-24-2018, 02:07 PM
