    So all this week I would take it odd and the battery would last like 6-7 hours which is usual. Today I took it off at 80% (while it was plugged in) and it says only like a hour.
    04-28-2018 04:26 PM
  2. Rukbat's Avatar
    Was your usage pattern the same, or did you use it a lot more today?
    And how old is it? Rapid discharge is one of the signs of a failing battery. (Also, how low do you usually let it discharge? Too low for too long [and 5% for a month is all it takes] will kill it pretty quickly.)
    04-28-2018 05:49 PM
  1. Xperia Z5 compact not syncing contacts
    Last Post: 05-01-2018, 05:03 AM
  2. my apps not update please hlep me
    Last Post: 04-28-2018, 07:59 PM
  3. My phone puts me to ads at random
    Last Post: 04-28-2018, 07:42 PM
  4. Replies: 1
    Last Post: 04-28-2018, 06:03 PM
  5. File shortcut on homescreen deleted my videos
    Last Post: 04-28-2018, 05:31 PM
