    This last week both the cameras on mine and my husband's LG G5 has stopped focusing. Any one having this problem? Is there a solution?7
    05-06-2018 06:35 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this also happen in Safe Mode? https://support.t-mobile.com/docs/DOC-30620
    05-07-2018 02:35 AM
  3. Tonya Whitus's Avatar
    Yes, will still not focus in safe mode. The wide angle is fine. It just happens in normal setting
    07-12-2018 12:06 PM
  4. Rukbat's Avatar
    That sounds like a camera module failure, meaning that the module has to be replaced. Unless the problem started for both of you right after you got updates, the fact that it happened to both phones is just a coincidence.
    07-12-2018 12:45 PM
  1. How do i unblock my T Mobile LG V20?
    By Bori523 in forum LG V20
    Last Post: 05-11-2018, 12:28 PM
  2. LG V30+ question?
    By eak1570 in forum LG V30
    Last Post: 05-06-2018, 06:39 PM
  3. Display at LG G5 is not working
    By Android Central Question in forum LG G5
    Last Post: 05-06-2018, 04:18 PM
  4. Display at LG G5 is not working
  5. How do i unblock my lg v20?
    Last Post: 05-06-2018, 04:10 PM
