    My Samsung Galaxy S7 edge(the international version) won't ring during incoming calls..after a while I recieve notifications that I have missed calls.
    The person calling me, seems that I have rejected the call and it goes directly to the voicemail. I have done a Factory Reset, a soft reset (power & down volume key), but nothing happen. The same could happen if I would like to send a text, when I press the send button, it tells me "Did not send" and if I re-send the text, then will be delivered. P.S.this problem does not happen all the time.Any thoughts
    05-08-2018 05:18 PM
  2. methodman89's Avatar
    Open your phone app, go to Settings, make sure 'always forward calls' is off. Check out all of your other settings while you are in there, I. E. Volume of incoming calls. Get familiar with them.
    05-08-2018 06:12 PM
  1. Why doesn’t an assigned ringtone ring as it’s supposed to?
    By Joetheauthor in forum Ask a Question
    Last Post: 05-16-2018, 01:06 AM
  2. Full notifications on lockscreen
    By DotsFar in forum Nokia 8 & Nokia 8 Sirocco
    Last Post: 05-13-2018, 11:57 AM
  3. Replies: 1
    Last Post: 05-09-2018, 11:35 AM
  4. How much does it cost to get the bottom of my LG Aristo fixed?
    Last Post: 05-08-2018, 06:20 PM
  5. How do I connect a Samsung S9 to my 2015 Jeep..
    Last Post: 05-08-2018, 04:20 PM
