    My phone keeps telling me that my battery is draining faster than it's charging when I got it plugged in
    05-10-2018 01:04 PM
  2. belodion's Avatar
    And is it?
    05-10-2018 01:09 PM
  3. Mooncatt's Avatar
    Usually that's due to a bad USB cable. If replacing that doesn't work, a new charger would be the next thing to check. After that, I'd investigate if it's a bad connection inside the phone. It may be the battery itself, but that's highly unlikely with this type of symptom.
    05-10-2018 01:22 PM
  1. Replies: 5
    Last Post: 05-26-2018, 07:22 PM
  2. Replies: 3
    Last Post: 05-12-2018, 05:09 PM
  3. Oreo, General Mobile GM5 Plus and battery drain.
    By scottsan in forum General Help and How To
    Last Post: 05-11-2018, 02:03 PM
  4. Why is my FDT View app failing to install when it worked fine on Android 5.0
    Last Post: 05-10-2018, 12:01 PM
  5. My LG G Flex2 keeps restarting itself
    Last Post: 05-10-2018, 11:22 AM
