When I put location on my device will stuck or jam specially when open the map
If I open any location map the phone will jam an nothing can be opened with loading circle appear and keep on blinking
Re: When I put location on my device will stuck or jam specially when open the map
The GPS doesn't give you a loading circle, so it's not the location. You;ll have to troubleshoot further.
Welcome to Android Central! Which phone? Are you using Google Maps? If so, go to Settings>Apps, select Google Maps, then Storage, then Clear Cache/Clear Data. Now try again.
