    I have tried every plug and wire I have for this phone and nothing has worked
    05-24-2018 11:07 AM
  2. chanchan05's Avatar
    There's a possibility that battery was drained below critical charge. If that's the case only a battery replacement will work.
    Laura Knotek likes this.
    05-24-2018 11:55 AM
  3. Rukbat's Avatar
    Leave the charger plugged in for at least 3 hours. If it shows any sign of charge at that point, let it charge up to 80%. (If it's discharged too low, it has to be precharged, so it will stay at "0%" for quite a while. If the phone doesn't do precharging (most don't), you'll have to do as chanchan suggested and have the battery replaced. (In the future make 30% the "charge or turn off immediately" point. Even if you can precharge the battery, bringing it down that low shortens its life.)
    05-24-2018 01:41 PM
  1. I have a Pro12 tablet and I keep getting the settings password screen...
    Last Post: 05-25-2018, 10:03 PM
  2. Bluetooth speaker sounds blown when connected to my HTC U11
    Last Post: 05-24-2018, 02:11 PM
  3. How can I delete all photos at once
    Last Post: 05-24-2018, 12:30 PM
  4. Why do my wallpapers(lockscreen and homescreen) reset after reboot?
    Last Post: 05-24-2018, 12:28 PM
  5. how to bypass the request for last synced email account on ares
    Last Post: 05-24-2018, 08:59 AM
