    i didn't drop it or something. when i woke up and check my phone.. i saw this screen problem
    05-25-2018 08:08 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The screen is likely faulty. That stain might start spreading, which could lead to the screen completely failing, so make sure all of your important data is backed up or synced somewhere. Then bring the phone to a repair shop, or consider getting a new phone.
    05-25-2018 08:18 PM
  1. Why is there a "4" on my Internet Icon?
    Last Post: 05-25-2018, 08:27 PM
  2. phone drains faster than the estimated usage times
    By Zapster PLAYSMINECRAFT in forum Ask a Question
    Last Post: 05-25-2018, 08:21 PM
  3. how can i print imo call history
    Last Post: 05-25-2018, 08:20 PM
  4. How do i disable pop-ups on my Samsung Galaxy Grand prime
    Last Post: 05-25-2018, 08:19 PM
  5. how do I reduce number of rings before voicemail?
    Last Post: 05-25-2018, 04:46 PM
