    My power button will not work, possibly due to the fact that it is not connected to the phone but to a piece of tape holding it there. It is an android, the name it has is Huawei. I messed it up pretty bad, the back is still intact but it is kind of peeling right by the power button, that made it slip from its little hole. The screen is also cracked: I managed to pull up the button and tape it there, but it won't turn on. My phone was out of battery and turned off but when I charge it the screen works, but it will not power on.
    05-26-2018 07:35 PM
  2. Rukbat's Avatar
    The button just presses a switch behind it. The chance is that the switch is bad. The phone has to go into a repair shop. Get a rough estimate, because the repair may cost more than a new phone.
    05-27-2018 07:22 PM
  1. Hardwire Galaxy Note 5 to ethernet
    Last Post: 05-28-2018, 11:15 PM
  2. Pop Up Ads with Sound when phone is on Do Not Disturb
    By rguedel in forum Samsung Galaxy S7
    Last Post: 05-27-2018, 10:26 PM
  3. Touch wiz app keeps closing, even after reboot. At LAX need my phone to work
    Last Post: 05-27-2018, 10:25 PM
  4. Replies: 0
    Last Post: 05-26-2018, 06:18 PM
