    I can hear songs but while on call i call listen opponent voice but they can't hear muy voice can say any solution for this
    05-31-2018 03:05 PM
  2. SpookDroid's Avatar
    Is this a wired headset you're using? If so, have you tried it in another phone? Or tried a different pair of headphones in yours? Sounds like the wiring might not be compatible with your phone, which would explain why you can hear the other side but they can't hear you (basically the wire carrying the microphone signal isn't connected to where it should be).
    05-31-2018 03:56 PM
  1. Google Assistant problem
    Last Post: 06-04-2018, 03:05 PM
  2. Samsung note 8 problem
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 06-03-2018, 03:16 AM
  3. Have to redial twice to make a call
    Last Post: 06-01-2018, 08:23 AM
  4. How do I get rid of MM Phone notification. Emergency calls only?
    Last Post: 05-31-2018, 04:35 PM
  5. Samsung note 8 problem
    Last Post: 05-31-2018, 03:38 AM
