    I only change my screen an than i fixed ready my camera dont work
    06-03-2018 10:05 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you saying that you replaced your phone's screen yourself? If so, then it's probably something you did during the repair process -- maybe you dislodged a connection. Also, if you had to replace the screen because it was broken from a fall, then it's possible the camera got damaged from that trauma as well.
    06-03-2018 10:35 PM
  1. App/Task/Button to change camera resolution?
    By jbsjbs in forum General Help and How To
    Last Post: 06-04-2018, 01:40 AM
  2. Somebody hacked my phone how do I fix it
    Last Post: 06-03-2018, 11:26 PM
  3. gps draining my battery. How to disable auto-on gps?
    Last Post: 06-03-2018, 10:39 PM
  4. How to fix this camera bug?
    Last Post: 06-03-2018, 10:38 PM
  5. Some of the letters on my Android tablet aren't working
    Last Post: 06-03-2018, 10:37 PM
