    I dropped my phone in the toilet and managed to get it out. I wiped it down with a towel and placed it in a bag of rice and left it there for 4 hours. After that I got a vacuum and attempted to duck all the moisture from the phone. I then tried to turn it on and it works perfectly! Bit now my screen brightness keeps on changing every time I keep on applying pressure to the screen and this is dust rating whilst trying to use the touch screen. Does this mean that it has water still in it and (if so) will I need to use some other method or not?
    06-04-2018 03:50 PM
  2. belodion's Avatar
    Water damages phones, and so do the residues remaining after the water has dried. Swishing in alcohol may help.
    See this: https://forums.androidcentral.com/sh...d.php?t=477140
    06-04-2018 06:31 PM
  3. L0n3N1nja's Avatar
    The rice thing usually takes a day or more for the phone to dry out, odds are there is still some moisture in it, or that something was damaged by said moisture while the phone was powered on.
    06-04-2018 06:52 PM
  1. Can't find docs, pics, videos in My Files when connected to a PC
    By tomgraz in forum Samsung Galaxy Note 3
    Last Post: 06-07-2018, 02:49 PM
  2. Phone keeps connecting to WiFi network I've repeatedly told it to forget
    Last Post: 06-04-2018, 03:21 PM
  3. Hey Google, works, however the reply is written, I want the answers spoken aloud
    Last Post: 06-04-2018, 03:10 PM
  4. Why does my android 7.0 continue to reset to 15 sec display time?
    By Jimerhossa in forum Android 7.0 Nougat
    Last Post: 06-04-2018, 01:58 PM
  5. Triangle on my status bar
    Last Post: 06-04-2018, 01:54 PM
